8 members (David Bush, kades51, BC59, MikeE, Bucker, MickeyP, Rexville48, dt235sd), 97 guests, and 1 robot.
Topics128,049
Posts1,055,702
#1158774 04/06/2016 3:45 AM
Does anyone have the exact location for the jump seat brackets?
oldburbs #1159964 04/12/2016 4:11 PM
Nobody knows the location dimensions of the frt. Passengers seat?
oldburbs #1159984 04/12/2016 5:54 PM
oldburbs,
I could measure mine when I get to see it next week.
But, I had parts of my floor replaced, and I did not know where the seat should be located. So, we mounted the drivers 70% seat and then placed the jump seat on the floor. We simply placed aluminum "skids/lifts/risers" under the jump seat's base, until it was level with driver's seat. We then bolted the skids/risers through the floor and the base of the jump seat to (or through) the "skids/risers".
Does your Suburban have a rough-cut-looking metal plate/base attached to the floor under the jump seat? Mine had been removed.
I think bowtietim posted a photo of the rough metal plate under the jump seat?
oldburbs #1160151 04/13/2016 1:53 PM
oldburbs #1160226 04/13/2016 9:44 PM
Nice, Mark - thanks
What is the thickness of that plate?
oldburbs #1160322 04/14/2016 2:15 PM
It measured out to somewhere around 14 gauge.
oldburbs #1160323 04/14/2016 2:19 PM
Thank you, Mark
oldburbs #1160372 04/14/2016 7:21 PM
You bet!!
