Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Otto Skorzeny, Gdads51, Southerntruck, sron48), 52 guests, and 3 robots.
Topics128,008
Posts1,055,285
Members48,418
#115992 01/09/2002 7:04 PM
If i already have a primer down can I put zero rust over the primer or do I need to strip it and put zero rust on the bare metal to receive the benefits of zero rust
#115993 01/09/2002 7:55 PM
Brady,
Understand we are talking shades of gray here, but yes the ZR would work better direct to metal. It's resistance to undercutting and encroachment of rust sideways will be lessened with the primer on, but unless you are planning on going around punching holes in the paint and leaving them unrepaired for extended periods, I doubt you'd ever know the difference, even in Ms.
Bruce Palmer
[email protected]
#115994 01/09/2002 10:49 PM
Bruce,
I have had my c.o.e. body acid dipped,would it be a problem if I sprayed the outside to keep from rusting before sending it out for final body work and paint, or should I leave the outside bare until the body shop finishes there work? I still need to use some of the body parts for fit-up and I know handling them with bare hands will start rusting again.Thank you for your help..
It's what you learn after you know it all that counts.......
#115995 01/10/2002 1:34 AM
My recent research has taught me you need to epoxy prime your pieces to avoid the rust. Zero Rust may not agree with the paints used later on but would be perfect for the underneath and inside of the cab and fenders.
54 3100 with 235
62 flatbed dump C60 with 261
#115996 01/10/2002 1:56 AM
Tony is right and I tend to assume everyone has made that connection. Zero Rust is best used where it will provide it's sealing protection by itself.
A lifting problem under some of the mega $$$$ topcoats out there will put a real severe hole in a guy's lunch money to say nothing of the ol' attitude. Now that's not to say you can't slobber undercoat or bedliner all over ZR, just be careful with the $150/gallon stuff.
As for the COE, I would think the body guys would want it raw to do the body work and unless they are storing it underwater, they should have plenty of open time before problems occur.
Bruce Palmer
[email protected]
#115997 01/10/2002 2:34 AM
Thanks for the help Tony and Bruce. Epoxy primer it will be.I just need to handle it a lot before it goes to body shop.
#115998 01/11/2002 12:13 AM
If I put zero rust down and then other primers over will the paint lift later on.
Brady Eldridge #363916 01/22/2008 2:08 AM
That's what I'd like to know too, Brady.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Old Gold #364089 01/22/2008 2:22 PM
Houston54
Unregistered
Houston54
Unregistered
I have used ZR exclusively on my 54 from frame to body but on the previous advice of Bruce I did not use it on the top surfaces of the body with the exception of one panel.
The rear panel I transplanted to the 5 window cab had been previously stripped to bare, metal prepped and then coated with black ZR. It sat this way for about two years before I removed from the old cab for the transplant. Once the panel was on I scuffed it with 220 grit and then primed over that with Epoxy Primer. It was another year before I did further prep on that panel for the top coat which included additional sandable primer and then a final seal coat of epoxy primer before the color was laid down. I do not believe I will have any problems with the paint system but I would not use ZR as an initial base without letting it cure very well over a matter of months then prepping it as I described.
ZR Rocks in my opinion.
#364146 01/22/2008 5:35 PM
WOW!! Six years between messages? Seem like just yesterday. wink
A couple of points should be touched on here. The first having to do with shrinkage. ZR being 54% solids by volume will shrink 50% during the drying phase thus shrinking down into any surface defects telegraphing any sanding scratches thru the final finish. If that isn't going to be a problem you may apply your top coat almost wet on wet and allow the two to cure out together.
If shrinkage and telegraphing will be a problem, allow the ZR thirty days to achieve full shrinkage and build your sandable sytem on top of the fully cured ZR film. Fully cured ZR should have no adverse reaction to subsequent coatings. If there were to be a reaction, it would happen more NOW than LATER.
