7 members (32Fordpuchoptop, 3B, TUTS 59, Shardean, msmall, carbking, Bill Hanlon), 51 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#115981 08/19/2004 10:17 PM
Junior Member
Junior Member
Hello everyone,
Any advice on removing the windshield in a 1958 Chevy.
I have already removed the SS trim. The gasket is only 5 years old and I hope to save it and reuse.
Paul
Paul
When you do a good deed, get a receipt just incase HEAVEN is
like....the IRS
#115982 08/20/2004 5:46 PM
It's pretty hard to save and reuse a gasket, but if you work a flat stick under the gasket from the inside and work it over the pinch weld while gently pushing out the window you may be able to remove it without cutting it or breaking the glass.
Paint & Body Shop moderator
#115983 08/20/2004 11:44 PM
1 Offline
Oh boy. I've removed more than a couple of
windshields from TF trucks but I have never
attempted to save the seel. As Josiah sug-
gested but I'd go after it with a couple of
plastic paint sticks (no splintering) and
some soapy water.
Good luck!
[img]http://www.norcalspeedshop.com/_offsite_images/1956_01b.gif[/img]
- AJ
