4 members (Otto Skorzeny, moparguy, delky, 1 invisible), 104 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#1159718 04/11/2016 12:19 PM
S0 my new rebuilt gage cluster came with the temp sending unit to go to my 216.
The oil pressure line was not included,and after all this time ,I have no idea where on my 216 that should connect to.
Any help would be appreciated,including pic's
just-a-hacker
'49 3100 before '99
Here is a reproduction oil pressure line for a 216 (and a 235/261 with the "mechanical" sender/gauge).
F Online: Content
Connection to block is under rear of manifold approx 6-7" in front of rear block coolant drain plug.
Ed
ok,
I'll look there
just-a-hacker
'49 3100 before '99
Sorry about not posting a photo.
The oil pressure sender line can be seen in this photo.
This photo shows the oil pressure line attached to a T fitting in the block with the oil filter line.
If you have a bypass oil filter, it (the oil pressure gauge) is T'eed to the line to the filter. If you don't(many do not) it is connected to the fitting that would have gone to the filter. Step 12 on this page( I know not helping): http://chevy.oldcarmanualproject.com/shop/1947truck/47ctsm0619.htm
So, many thanks to tcleaderman for his picture. That little tiny line below the line to the oil distributer fitting.
Steve H
Tim,Steve,
Thanks, I will look there for whatever is plugging that hole now
I really appreciate the pic !!!!
just-a-hacker
'49 3100 before '99
