9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible),
43
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | The screws on my '54 driver side lower windlace holder came out without a problem. My passenger side one are much more rusted, nearly stripped, and they are stuck. I've soaked them in penetrating oil, tried everything and they won't budge. I was wondering if anyone had suggestions on what I may be able to do?
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://www.stovebolt.com/techtips/bolt_removal.htmlTry propane torch heat. Try penetrating oil and tapping/punching with a hammer on a screwdriver in the head of the screw. Try to punch the screw from below. Can you get a vise-grip on the head? My WAG regarding why the "outside" screws are harder to remove: that's the wetter side of the road? | | | | | Joined: Jan 2016 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 35 | Excuse my ignorance, but what is a windlace? I've seen it mentioned on here before but never any pictures and I've Googled it without results. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It is one name for the rubber seal that is attached to the door opening on the cab: the "door opening weatherstrip" In your 1953, the upper windlace (door opening weatherstrip) is held in a channel that goes around the opening of the door - except at the floor, at the door opening (see link below, "body sill weatherstrip retainer"). In the lower door opening - at the floor, that lower rubber windlace seal in held down with a metal strip. lower windlace door opening, upper windlace Here is the metal strip - lower windlace retainer (referred-to in step 11: "body sill weatherstrip retainer") | | | | | Joined: Jan 2016 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 35 | Thanks. I need to replace all mine as well.
| | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | Yeah, I wanted to see if I could get it without a torch since they are in the interior of the cab. I don't want to discolor the paint on the rail. Although the screws are rusted the rail is in great shape. I tried hammering with a screw driver but they just don't budge.
I've never drilled out a screw and wasn't sure if maybe that could be an option. Or maybe a screw extractor (also never used)
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Those are sheet metal screws if I remember correctly, and you can access the bottom of the screw from under the cab (again, if I remember correctly. Soak the bottom with PB to start. If that doesn't work use the torch on the bottom or use a hand grinder and grind the point of the screw off. The heat and vibration will loosen them up. | | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | Okay, so I actually got them out! I drilled them out just enough to get a better seat with the screwdriver. I tapped them enough with a hammer and they spun out. Thanks!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | We have a tech tip in the works on installing cab windlace. It looks pretty straight forward (well written). It should be easy to put together. We are waiting for two more images.
Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Since I just struggled with one side, I'll wait for some tips on the other side
I used plenty of soap and water (and some grease) I did have to open up the channel in several places | | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | Does anyone else agree that windlace was created by the devil? I think I've used up more hours trying to push this stuff in those grooves than anything else I've done on this truck. There must be an easier way!!!
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Does anyone else agree that windlace was created by the devil? I think I've used up more hours trying to push this stuff in those grooves than anything else I've done on this truck. There must be an easier way!!! There is. Buy an early '49 or earlier truck. They screw on.
| | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | hacker, I took a day break from the windlace and started on the passenger today. I sprayed the channel with liquid wrench spray lube and I found that the winblace slid much easier than when I used soap. Then the parts that didn't catch I just pushed in with a screw driver. Hope this may help you.
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | hacker, I took a day break from the windlace and started on the passenger today. I sprayed the channel with liquid wrench spray lube and I found that the winblace slid much easier than when I used soap. Then the parts that didn't catch I just pushed in with a screw driver. Hope this may help you. I have taken a few weeks break from the windlace after I got one side in,I also saw somewhere a note about putting headliner in first...good excuse to not install driver's side yet. most of my windlace doesn't come near door | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | I used "personal lubricant" from the drug store. Cleans up with water and the wind lace popped right into the channel with a little persuasion from a plastic automotive trim stick. Hope this helps.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim's method is the correct answer: use a non-oil-based and non-silicone-containing lubricant AND widening all the "pinch" locations in the channels/tracks. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Tim, Why do I think Woody probably would have made a special tool for this job . | | |
