9 members (TooMany2count, Opelika Tom, Otto Skorzeny, 78buckshot, TrknGMC, Charles in CA, MikeE, Wayne67vert, TexasA&M48Truck),
59
0
Mod | | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 148 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 148 | First, I'm trying to be good about using the search function so I don't clog up this amazing resource with repeated questions. So please excuse me if this has been discussed before.
I have recently purchased a 1953 2 ton GMC (350-24) and I'm slowly collecting a ton of questions in my project notebook. The wheelbase is 161" and I plan to build my own 8' by 12' flatbed for it (originally had a grain bed). It came without an engine and transmission, so I'm going to shoehorn a 454 BBC under the hood for locomotion.
One question I'm having trouble finding an answer to is what kind of shock absorbers I can use on this truck. The truck I purchased doesn't seem to have any shocks up front or in back. Did it come this way from the factory? And if so, could I adapted some tube shocks from something like a mid 70's Chevy C50? Or would the C40, or even C60 be something closer to what I need? I am completely comfortable and equipped at making any kind of mounts to do the job correctly.
If it helps, the ID tag on the drivers side, inside hinge area says the "Gross Vehicle Weight" is 16,000 lbs. Would like to adapt some shocks to this truck that are a close match for it's capacity.
Thanks in advance for your thoughts on this.
David
-David
1953 2-Ton GMC
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There were/are no shocks on my 1954 GMC 350 (2-ton). It has very stiff springs. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I have a 55.2 and 58 2-ton (both Chevys) and neither one came with shocks. (neither did my 41 Ford COE for that matter) From what I can tell from research, shocks were an option. A lot of these trucks were, as yours is, "grain trucks" and spent most of their live bouncing around in the field, and then driving on a gravel or dirt road a few miles to the grain elevator to be unloaded and then back home. I guess the thought was, not much need for shocks in that scenario. I pulled the shocks and mounts off my Ford P-500 before I scrapped it and plan to use them on my 2-ton at some point.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I have the optional shocks on my '52 GMC F470-32 COE. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Front & back, Spanky?
What is your opinion regarding adding them to a 350?
| | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | My '57 5700 LCF must be a deluxe cruiser, I believe the front shocks are original, none in the rear. 16000 lb. GVWR, 161.5 wheel base, grain box.
| | | | | Joined: Feb 2016 Posts: 148 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 148 | Thank you everyone for the replies! I didn't realize that shocks where an option for this thing.
Because the future of this truck will be mainly for hauling heavy loads on the smooth open highway, I'm hoping it wont hurt any to install some kind of dampening. As I slowly bring this "BigBolt" back to life, I'll post how I do things in the hopes it helps others too.
David
-David
1953 2-Ton GMC
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | David, My Chevy '50 COE has no shocks, a wheelbase of 158" and GVW of 16,000 lbs. I usually drive it for fun empty (weight about 7500 lbs) and the springs are very stiff. The heaviest load since I restored it was about 5000 lbs and all that did was make the ride noticeably smoother. I have never noticed a bounce in the ride empty or loaded and never thought about the need for shock absorbers. I doubt it would hurt to add shocks but from my perspective there may be other things you will find are more important to make your truck more enjoyable. Good Luck and keep us informed. Kent | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | For what its worth, the WW2 era Chevy and GMC military trucks all came with front and rear Delco double action lever shocks. | | |
