4 members (DBJ71SuperCustom, Stovebolt48, klhansen, Oswald), 124 guests, and 4 robots.
Topics128,196
Posts1,057,396
Members48,469
is there a difference in a 1992 T5 from a 4 cyl S10 and a 6 cyl S10? Is one better for my 57 Chevy truck or are they the same? thanks
Two 1957 Chevy Step Sides
1988 Fiero Formula
1987 Fiero GT
1984 Fiero Indy
... yes I like Fieros also..
Crusing in the Passing Lane
Read 'lugnutz' ' excellent article just below your entry on Driveline, 'will it fit'
Ed
Yes, they kept getting a bit stronger as engines got bigger. Best one would be behind a V8 Camaro. There are lots of good articles on these tranys, even found some good info on Youtube.
I'm sure there is some tech info here. I'd do a Google search as well.
1946 1/2-Ton Chevy
So am I to conclude there IS a difference between GM T5's originally used in 4 cly and 6 cyl S10's? thx
1988 Fiero Formula
1987 Fiero GT
1984 Fiero Indy
Yes, cyl had steeper 1st gear.
Tommy
59 apache 1/2t
261 short stepside
Careful with the Camaro ones. If I'm not mistaken, they are clocked differently from the s-10 ones. Meaning the shifter isn't at the 12 o'clock position.
Matt
Blacktop Cannibals Car Club
1954 Chevy mild custom car
1955 Chevy second series 3200
DadsApache, strenght isn't a problem with either trans. Main issue is 1st and 5th gear ratios. Ratios are all over the board for both 4 and 6 cyl trans. Most import to get the tag or sticker number and use the net to determine ratio's.
One common referenced site is; http://www.britishv8.org/articles/borg-warner-t5-id-tags.htm
The number you need will be 13-52-??? no others will help.
If you plan to run a mechanical speedometer you need to stay older than 86?, I could be off a year there.
Lugnutz (member here) also recommends turning input shaft and counting output shaft turns to absolutely test ratios. For a stockish engine I like a 1st gear in the high 3's low 4's with an overdrive ratio of 0.72.
Good Luck,
Ron
RonR
1970 340 Duster
1964 CJ5
The Camaro T5 has the same shape case as the S10 trucks. It is not clocked. The Camaro bell housing is the reason for the apparent difference. This LINK to my website explains why the transmission is clocked when using a Camaro bell. My 1965 C10 has a standard cast iron bell and a Camaro T5. There is no rotation of the T5.
In general, the 4 cylinder S10 trucks have a 4.03 1st gear and a 0.86 OD gear but I do not consider that a hard and fast rule. The 6 cylinder trucks usually have a 3.75 first gear and a 0.72 OD. The V6 Camaro is usually the same gearing as the V6 truck. The V8 Camaro has a 2.95 1st gear. The earlier V8 Camaros had a 0.72 OD gear. Later they changed the OD gear to 0.63 which is not good for a lower HP inline six. The 0.72 is better for an inline 6. The 0.63 is OK if you have more HP such as a SBC V8.
Originally Posted by moparguy
DadsApache, strength isn't a problem with either trans. Main issue is 1st and 5th gear ratios. Ratios are all over the board for both 4 and 6 cyl trans. Most import to get the tag or sticker number and use the net to determine ratio's.
Good Luck,
Ron
The cable speedo connection is found on 1988 and earlier S10 and GMC S15 and Sonoma trucks. All Camaro T5s have a cable speedo connection but the shifter is not in the correct position for a bench seat. It's too far back for a bench seat. I made a hybrid T5 for myself. I combined a V8 Camaro with a cable connection S10 tail housing. It gives me the nice V8 gearing and I was able to keep my factory cable speedo and my bench seat.
The metal tag has a 1352-### and it can also be found on a sticker on the lid. That is the only number used to identify the T5 using charts. The numbers cast into the metal are part numbers and not useful to determine the gearing. THIS LINK is a good review of what some of the markings mean.
World class and non-world class have similar strength. The general rule is 250 HP and 300 ft-lb of torque is the limit. I know for sure that people mate them to much more power and torque but drive normally and they do fine. They will not take abuse.
Pay attention to rear end ratio and tire size when deciding which gears will work best for you. There are calculators that will tell you what road speed and engine speed will result from different combinations of rear axle ratio, tire size and trans gear. I used them to size 1st and 5th to match a 3.42 rear.
If you are going to run aftermarket gauges you do not need to worry about finding a box with the speedo gear drive. I am running a programmable AutoMeter speedo directly off of the pulse output from what I believe is a '89 S10 box. Finding a trans with pulse output is generally easier and cheaper than with the mechanical drive.
___________________
58 Suburban
64 Camino
Thanks for all the replies!
1988 Fiero Formula
1987 Fiero GT
1984 Fiero Indy
