6 members (NJC, KCMongo, 59 fleet, Brian Moore, 42465967, Wally / Montana), 81 guests, and 2 robots.
Topics128,034
Posts1,055,539
Members48,425
#1158598 04/05/2016 1:54 PM
1957, 3800 used to have a grain bed but I'll put a 9' stepside bed on later this summer. I changed it from dual rear wheels to singles, R8-19.5. It'll never be loaded heavily again and I live on a gravel road do I'd like to find a simple way to soften the ride a little. Two things that have to come to my mind are (1) remove a leaf or 2 from each spring pack or (2) change out the springs for some from a 3/4 ton. Any suggestions will be appreciated. Thanks.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #1158619 04/05/2016 3:39 PM
Crusing in the Passing Lane
Remove leaves, including overloads, can stack them differently to maintain orig. ride height.
Ed
EdPruss #1158630 04/05/2016 4:44 PM
Hi Jfnar
I had the same deal with my 1 ton "Howard Knapp" truck...it was a 1 ton with a lot of leaf springs in the back....I carefully removed all the hangers and went to the a junk yard and ordered a pair of late 1990's leaf springs for it...I even used the 1990's shackle mounts too...
rear side view...
rear view here
It took I bet 1 week solid to get everything lined up and fit into place....make sure everything is square ....measure measure measure...shocks I got from Rock Auto and the hanging hardware I think came from Speedway Motors...all in all...not too hard to swap over...
Oh yeah...I swapped the rear-end out for a 1985 Chevy K5 Blazer while I was in there cuttin and choppin...
Good luck
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
jfnar #1158637 04/05/2016 5:18 PM
jfnar,
This rear-springs page from the 1957 Truck Specifications Manual might give you guidance on which springs might be safely removed?
My guess is the spring-pack you have (most likely RPO-254 - HD springs) came with the dual-wheel option package (RPO-462 - dual rear wheels)?
jfnar #1158659 04/05/2016 7:17 PM
Big Bolt Forum Moderator
when I did the ones on my Suburban, I left the original top leaf (cold not get to one of the hangers because of the 2nd tank added way back when before I owned it). I then added leaves from a newer truck (3/4 ton I think) and got the ride I wanted. That way, there was no replacing hangers on the frame (not that it is a big deal), and you can add/remove an individual leaf as needed.
Mike
Moderated by  Dusty53
