| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | 1957, 3800 used to have a grain bed but I'll put a 9' stepside bed on later this summer. I changed it from dual rear wheels to singles, R8-19.5. It'll never be loaded heavily again and I live on a gravel road do I'd like to find a simple way to soften the ride a little. Two things that have to come to my mind are (1) remove a leaf or 2 from each spring pack or (2) change out the springs for some from a 3/4 ton. Any suggestions will be appreciated. Thanks.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Remove leaves, including overloads, can stack them differently to maintain orig. ride height.
Ed
| | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi Jfnar I had the same deal with my 1 ton "Howard Knapp" truck...it was a 1 ton with a lot of leaf springs in the back....I carefully removed all the hangers and went to the a junk yard and ordered a pair of late 1990's leaf springs for it...I even used the 1990's shackle mounts too... rear side view... rear view here It took I bet 1 week solid to get everything lined up and fit into place....make sure everything is square ....measure measure measure...shocks I got from Rock Auto and the hanging hardware I think came from Speedway Motors...all in all...not too hard to swap over... Oh yeah...I swapped the rear-end out for a 1985 Chevy K5 Blazer while I was in there cuttin and choppin... Good luck MikeC
1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | jfnar, This rear-springs page from the 1957 Truck Specifications Manual might give you guidance on which springs might be safely removed? My guess is the spring-pack you have (most likely RPO-254 - HD springs) came with the dual-wheel option package (RPO-462 - dual rear wheels)? | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | when I did the ones on my Suburban, I left the original top leaf (cold not get to one of the hangers because of the 2nd tank added way back when before I owned it). I then added leaves from a newer truck (3/4 ton I think) and got the ride I wanted. That way, there was no replacing hangers on the frame (not that it is a big deal), and you can add/remove an individual leaf as needed. | | |
