0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#1158404 04/04/2016 6:09 PM
Needing a vendor that has these flat U clips that are all around this grille. Found generic assortments but there seams to be a zillion sizes and styles. Have found kits that have the screws but no luck with U clips (if that's the proper name for them)?
1946 1/2-Ton Chevy
Give me ambiguity
or give me something else
Thanks will check
1946 1/2-Ton Chevy
They're called speed nuts or clip nuts.
That Dorman link that Caso posted only showed metric ones.nono Can't use those on a stovebolt wink
The auto parts stores typically have the right (Std thread) ones in their "Help" section, or they may have a sample book behind the counter.
Picky picky picki brrrrr
try to point a guy in a direction... even get him in the right neighborhood and catch flack for not showing him the checkout stand with his order ready to go...
Next time I'll just link to the front page of their site and leave em to their own devices I guess secret dang
Give me ambiguity
CASO #1158570 04/05/2016 4:35 AM
I wasn't trying to bust your chops CASO, just wanted to make sure the OP didn't put anything METRIC eek on his stovebolt. If anything I fault Dorman for not having them in their catalog. Cheers to you for the suggestion. chug
Ok lots of good direction here many thanks. I'm attempting to save some clips off a couple munched spare grills, will see if there is anything left after bead blasting. Grill is at the powder coater now, good thing I have the spares, even this CA grill is rusted through in some places.
1946 1/2-Ton Chevy
DADS50, Where did you purchase those screws #443360 Also that looks like a dealer promo truck no?
Jim
1946 1/2-Ton Chevy
I believe I purchased those screws at autozone.....(needa?.. ) is the Brand Name
...used them around the lower shield...
The truck is 1/25 old navy
Ok Autozone it is, will check that out. The clips cleaned up pretty nice and between the three grills, should have enough to do my good one. All the screws though are pretty rusty. Powder coat on the grill will be a bright silver for the horizontal bars front half with white on the back, verticals will be black.
1946 1/2-Ton Chevy
