| | | Forums66 Topics128,041 Posts1,055,593 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Needing a vendor that has these flat U clips that are all around this grille. Found generic assortments but there seams to be a zillion sizes and styles. Have found kits that have the screws but no luck with U clips (if that's the proper name for them)? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | | | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | They're called speed nuts or clip nuts. That Dorman link that Caso posted only showed metric ones.  Can't use those on a stovebolt  The auto parts stores typically have the right (Std thread) ones in their "Help" section, or they may have a sample book behind the counter.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Picky picky picki  try to point a guy in a direction... even get him in the right neighborhood and catch flack for not showing him the checkout stand with his order ready to go... Next time I'll just link to the front page of their site and leave em to their own devices I guess
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | Picky picky picki  try to point a guy in a direction... even get him in the right neighborhood and catch flack for not showing him the checkout stand with his order ready to go... Next time I'll just link to the front page of their site and leave em to their own devices I guess  I wasn't trying to bust your chops CASO, just wanted to make sure the OP didn't put anything METRIC  on his stovebolt. If anything I fault Dorman for not having them in their catalog. Cheers to you for the suggestion.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Ok lots of good direction here many thanks. I'm attempting to save some clips off a couple munched spare grills, will see if there is anything left after bead blasting. Grill is at the powder coater now, good thing I have the spares, even this CA grill is rusted through in some places. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | DADS50, Where did you purchase those screws #443360 Also that looks like a dealer promo truck no? Thanks Jim | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Ok Autozone it is, will check that out. The clips cleaned up pretty nice and between the three grills, should have enough to do my good one. All the screws though are pretty rusty. Powder coat on the grill will be a bright silver for the horizontal bars front half with white on the back, verticals will be black.
