3 members (Hanks custodian, wilbur53, Donf), 111 guests, and 3 robots.
Topics128,038
Posts1,055,584
#1158171 04/02/2016 11:17 PM
2005 Borg Warner T5 transmission. The code is 1352-216
Will it bolt up okay to my 1958GMC 1/2ton bell housing?
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
dtwbcs #1158181 04/03/2016 1:17 AM
The tag shows that it is from a 2.2L motor out of a 1993, and it is a World Class trans. (if the web site has it correct)
http://www.britishv8.org/articles/borg-warner-t5-id-tags.htm
That might be a ford bolt pattern? I'm not sure without looking at it. I think Lugnutz comes on this board, if he does he will answer your question. In the mean time, look through his web site, he has spent a Sh** load of time putting it together and it is one of, if not the best reference sites going on the T5
http://lugnutz65chevystepside.weebly.com/t5-info-page.html
Jim
52 Chevy tin woody with a stovebolt
dtwbcs #1158182 04/03/2016 1:36 AM
GPM
13-52-216
Borg Warner Automotive
61GPM U269679 On the paper tag
"cut one of the bolt ears off;That was professionally welded back on. Has a 26 spline input shaft.
Danny
dtwbcs #1158287 04/03/2016 10:34 PM
I'm going to say no off-hand. I bought one of them awhile back. It actually has a Ford pattern on the trasmission, vs. the GM Muncie style.
At the very least, you would need a Ford-Muncie adapter.
Some of the early 90's F-bodies used the 26 spline shaft. You'll probably need the F body clutch disc and pressure plate if you go with it.
Does it look like this? http://s1074.photobucket.com/user/w...ans2_zps71c6b402.png.html?sort=3&o=0
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
dtwbcs #1158319 04/04/2016 2:07 AM
Yes , it looks like that on the input.
Danny
dtwbcs #1158334 04/04/2016 3:41 AM
I ended up selling mine and went another route. McLeod, Wilcap, and Advance Adapters make adapters. Get your checkbook out though. Don't really recall if any other modifications are needed.
"The Fake Truck"
dtwbcs #1158346 04/04/2016 4:30 AM
That's the ford bolt pattern. Gm used that in Astro vans s-10's and V 6 Camaros, they didn't stand up well to the v8 engines.
Tommy
59 apache 1/2t
261 short stepside
Tommy #1158403 04/04/2016 6:08 PM
As mentioned above, the BRITISH V8 T5 CHART lists the 1352-216 as a 1993 T5 from an S10 truck. That website has been wrong on a few things on occasion. Typically they have the gearing numbers incorrect.
I will assume you have a Muncie pattern bell housing.
1993 was the last year the S10 T5 had a Muncie pattern case. I have owned several of the 1993 S10 T5s and all were world class with a VSS speedo output.
It is possible that it could be a Ford case pattern if GM switched during the later part of the 1993 production. You really want to avoid a Ford case pattern in my opinion. The cost to make it work with a Muncie bell is substantial.
You would have to decide what to do about the speedometer. A CABLE-X conversion box is an option to convert VSS to a cable output but it's expensive.
My advice is this:
If it has a Ford pattern case - then pass and look for a Muncie pattern T5.
Make sure your rear diff gear will work well with an OD gear. The chart lists the 1352-216 as a 0.76 OD which will work really well with a 3.73 or 3.90 diff.
Be persistent with your search for a 1988 or earlier S10 T5 because they have a cable speedo connection. I usually find about 3 per year but I am always on the hunt. grin
Lugnutz #1158592 04/05/2016 11:58 AM
Thanks for the advice
Danny
