1 members (dt235sd),
101
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 1 Moderated | | Moderated Joined: Feb 2013 Posts: 1 | Where is a good source for exploded views of this truck? I am rebuilding the rear axle, brakes and suspension.
| | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 |
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have a good photo record of my 46 restoration that might help in photo bucket | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | I also have a '46 half ton, on which I put approx 750 miles each season (Apr- Nov). It is 100% original. It has become quite bouncy/bouncy. Do you recommend rebuildng lever-style shocks (which are evidently leaking) or replace those with modern conventional shocks? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Miss Church, Have you done the "Servicing Shock Absorbers" operations described in the Shop Manual. It has been a long time since I did them (once). I forget how easy/hard the operations are to carry out. | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | No but that's excellent advice . . . manual is in the shop and I'm not @ this moment but will read it Monday. Bless you. | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | OMG its right there in your attachment; seems straight forward, will do it next week & report back. Double blessings | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | What fluid is used in these that is currently available and compatible? Scott | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | When I restored my truck I had some shocks that were leaking so I took them apart and soaked the seals in transmission fluid and transmission fluid with the seal swelling additive. Neither fluid deteriorate the seal nor did they swell. I'm in MI and my truck is in WA other wise I could tell you the specific brand and type. but it has been working fine. | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | I just used motorcycle fork oil and it seems fine but my truck has not been on the road yet. Thanks Gene. Scott | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I use ATF in all of the shocks I rebuild.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | Any non-foaming hydraulic/transmission oil will work. Farm tractor hydraulic oil or hydraulic jack oil both work great. Mike B  | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Carter said he had the correct product, which I ordered and which turns out to be AutoZone Hydraulic Jack Oil. Thx to all for your input
| | | | | Joined: Oct 2008 Posts: 310 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 310 | Yep, I used hydraulic jack oil in mine and they work fine (for single action shocks). | | |
