Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Otto Skorzeny, UtahYork), 95 guests, and 5 robots.
Topics128,283
Posts1,058,505
Members48,490
Moderated
Moderated
Where is a good source for exploded views of this truck? I am rebuilding the rear axle, brakes and suspension.
Aggjon #1158003 04/01/2016 11:23 PM
Aggjon #1158030 04/02/2016 3:13 AM
I have a good photo record of my 46 restoration that might help in photo bucket
Aggjon #1158140 04/02/2016 7:50 PM
I also have a '46 half ton, on which I put approx 750 miles each season (Apr- Nov). It is 100% original. It has become quite bouncy/bouncy. Do you recommend rebuildng lever-style shocks (which are evidently leaking) or replace those with modern conventional shocks?
Aggjon #1158142 04/02/2016 8:01 PM
Miss Church,
Have you done the "Servicing Shock Absorbers" operations described in the Shop Manual. It has been a long time since I did them (once). I forget how easy/hard the operations are to carry out.
Aggjon #1158143 04/02/2016 8:03 PM
No but that's excellent advice . . . manual is in the shop and I'm not @ this moment but will read it Monday. Bless you.
OMG its right there in your attachment; seems straight forward, will do it next week & report back. Double blessings
What fluid is used in these that is currently available and compatible? Scott
When I restored my truck I had some shocks that were leaking so I took them apart and soaked the seals in transmission fluid and transmission fluid with the seal swelling additive. Neither fluid deteriorate the seal nor did they swell. I'm in MI and my truck is in WA other wise I could tell you the specific brand and type. but it has been working fine.
GWWirth #1158245 04/03/2016 5:32 PM
I just used motorcycle fork oil and it seems fine but my truck has not been on the road yet. Thanks Gene. Scott
Aggjon #1158310 04/04/2016 1:16 AM
I use ATF in all of the shocks I rebuild.
My Blog
Aggjon #1158572 04/05/2016 4:52 AM
Any non-foaming hydraulic/transmission oil will work.
Farm tractor hydraulic oil or hydraulic jack oil both work great.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Aggjon #1160220 04/13/2016 9:15 PM
Carter said he had the correct product, which I ordered and which turns out to be AutoZone Hydraulic Jack Oil. Thx to all for your input
Yep, I used hydraulic jack oil in mine and they work fine (for single action shocks).
