7 members (jmoore, kades51, Otto Skorzeny, TexasA&M48Truck, Frank50, Jon G, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,132 Posts1,056,379 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | I've been gone for a while...computer crashed. I have a question, my hood has came apart in the middle where the rivits hold it together. I tried to push it back and it just won't. I don't want to damage it more is there a easy way to do this. Drive a Heavy Chevy!.....It's pure American! | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Mine is held together with little nuts and bolts. I would drill some holes and just do that.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | thanks tony! It has a gap about 1/4 inch on the rounded front section . Hey what ever happened to the west coast stovebolt meet? Hard to organize a spot for everyone to meet! Well, maybe we'll plan one better in the future or look into planning a stovebolt rally? | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | CMayna and I went to the Pleasanton Good Guys swapmeet and car show a couple of weeks ago. They have several more shows during the year. If a bunch of stovebolters were to meet at the show, for $25 each we can display our trucks. If parked together this could make a real nice truck display if enough people show up. Sounds like a good place to meet. There is lots to do and other trucks and cars to see.
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Marlo, you still have the center strip on? Seems like there are tabs along seam inside to turn and lock sections together. Maybe that's just for the center strip not sure. Think there is a small gap for the strip to fit in, so if it's not there, will show up. Pinching together with those wide (4") or so welders vise-grips may draw up enough for bolts or ? needed to be used. If you check your manual on hood alignment, they not that at back underside of hood is a tension device to make hood "flex" and fit cowl tighter. Maybe you need to release/remove that to get tension off the hood sides and it will draw back easier then.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | tHANKS GL pERRY, I will have to give it a try and see if that is part of the problem. Hey Tony, That sounds like a great idea I think I'll try and make a few of those swaps/shows down your way! Living in Monterey is great and there are alot ole stovebolts running around here...maybe I can talk to a few and interest them in caravaning to a few shows. It's worth a try. Talk to you later. Thanks again for the advice guys.
Marlo | | |
