8 members (Forty9, Jon G, FAST55, NJC, Bill Hanlon, wilbur53, 2 invisible),
36
Mod | | | Forums66 Topics128,018 Posts1,055,245 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | Will the rear trailing arms interchange between a 1962 gmc and a 1972 ?
1962 GMC 920 step side 261 4 spd
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | The trailing arms are the same from 1960-72 for all 1/2 & 3/4 ton trucks with coil springs. Due to the arms splitting apart many will have an added plate on the bottom side either spot welded or riveted on. p/n 3881314 Mike B  | | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | Thanks I found a good clean pair on a 72 chassis, $100.00 but I got to pull them off.
