| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | 1949 3100 I have no idea where the wiring should be routed thru firewall,as po had cobbled the whole thing The assembly manual shows some of it,but not much detail. Does someone have a detail of where the different looms should come through ? firewall
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | thanks, can you tell me what item wires are coming out of which hole, Are the tailight and gas gage wires coming through at the hole nest to voltage regulator | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | The tailight wires come out of the hole to the right (in the picture) of the voltage regulator, and hook to the fuse box (small black rectangle). The ignition harness comes out of the hole to the left of the voltage regulator. The gas sender wire exits the bottom of the cab and re-enters with the harness to the right of the voltage regulator.
Are you making your own harness or using a pre-made one? | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | it is a harness from American Autowire,trying to make sure I don't run in wrong direction | | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | Light holders Dad, NICE JOB! | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | So most of the harness,except engine comes out the top drivers side hole ? | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | If you look in the FAM there is a picture of the firewall and all the holes are listed and what goes where. root | | | | | Joined: Mar 2008 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 70 | http://chevy.oldcarmanualproject.com/electrical/wiring/i hope this helps scroll down untill you get to the 49 click it and you can zoom in so close you can read the fine writing it helped me a lot now that i'm rewiring my 49 3100
frankenstein Fabrications
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | If you look in the FAM there is a picture of the firewall and all the holes are listed and what goes where. root "FAM" ? OH, factory assembly manual mine is a little vague, what section and page are we looking at ??
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | So the holes in my fenderwalls are .790 and none of the grommets supplied fit in those holes,and none of the assortment I purchased fit. Does anyone know where to get correct grommet ? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Hacker, what year truck are you working on? Mike B  | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Fenderwalls? Headlight wiring? So classic parts, part no. 37-821 not correct? Jim Carter LG-106 ? If not, and you have a 1949, your holes are wrong or someone sent you the wrong grommets or you asked for the wrong grommets or you didn't try hard enough to fit. What is the groove OD of the grommets you have and where did you get them?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Mike,"bartamos"
thanks , It is a 49 3100, I was able to re machine the grommets I had to fit.
now on to figure my horn...one step at a time | | |
