0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | On the cab floor there is a transmission cover. I have taken mine off to repair, when I reinstall do I caulk or weatherstrip that cover to seal out moisture? Or does it just go back metal to metal?
popcorn The Truth is Out There (Surely something goe there!) | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Weatherstrip. Most of the vendors sell them.
Winona 1949 3100 5 Window Deluxe Cab
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | popcorn,
The original-style weatherstrip was similar to thick roofing felt (Advance Design trucks). I found it did not make a good seal, so I used 1" wide vinyl window/door weatherstrip that had adhesive on one side (Home Depot). Though it is not like the original, it seals better and allows for easy removal/repacement of the transmission cover (you can't see it anyway).
Tim | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | 3M makes a body caulk that would work well for that purpose. I used it on the tranny cover of my CJ-5 and it made a good seal. It comes in a squeeze tube.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Thank you Gentleman and Young Lady!! Somebody had put a very cheap floor shifter in. Junk!! Anyway I am putting in a new steering column with shifter there. (more room on floor) Anyway the PO had not resealed and I knew something had to go there. Thank you again. Ben popcorn The Truth is Out There (Got to keep carpet and Maws feet dry  !) | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Several of the vendors sell the repop floor covers in fiberglass and/or metal. I think the 4 speed is "glass only and you can get the 3 speed in either.
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Josiah I'm going with the weatherstrip I got that on hand. Another question tho you brought up is the body caulk! Is that for the valleys like on the cab where they welded the skins together or put the cab together. (I do not know if I'm explaining it right) But I'm smoothing this cab out and there is a lot of seams that need something? Ben
popcorn The Truth is Out There (Thanks 49erGal, Tim. Also Josiah have you used that stuff?) | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would use seam sealer, it's made to stay some what flexable but you can paint over it. Most auto parts stores carry it. Scott | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Body caulk and seam sealer are very similar. You want the stuff to stay slightly flexible. It's a lot like plumber's putty or window glazing.
