Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (cmayna, baldeagle), 51 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#11576 11/13/2003 4:41 PM
Camp Commandant
Camp Commandant
I must admit that I haven't had time to look into what might be causing this problem yet, but hope to this weekend. The last couple of times that I have taken the truck for a spin it sputters and wants to die after a riding along in 4th at a higher rpm for several miles. With the gears that are in it, the truck will only run 40 to 45 miles per hour anyway so it easy to stay at a higher rpm for extended periods of time. It acts like the choke is stuck or its flooded. Other than that it starts up fine and runs good. Any suggestions on what to check first? Thanks, Bill.
~ Billy
1959 GMC 860 | Pictures
#11577 11/13/2003 5:25 PM
Make sure the vacuum advance makes the distributor turn when you stomp on the gas.
54 3100 with 235
62 flatbed dump C60 with 261
#11578 11/13/2003 5:39 PM
Fuel filter needs to be replaced?
Go thru the typical tune up route.
Check the Vacuum
Dist vac adv
Plugs
Wires
Fuel filter
Points
condenser
Cap
Rotor
Hopefully it will be something obvious
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#11579 11/13/2003 6:04 PM
Bondo Artiste
Bondo Artiste
Bill, Doug Peterson and his sweet 1953 Chevy, I think was having the same problem, maybe a sputter or two here and there and then it back fired on him....He lives in Md. and I had the chance to meet him this past summer, he is a great guy.
He replaced his vacumm advance and he said it now runs alot better.
~ Phillip
#11580 11/14/2003 12:59 AM
Camp Commandant
Camp Commandant
Thanks guys for the responces, I will look into the problem this weekend.
~ Billy
#11581 11/18/2003 12:16 AM
Camp Commandant
Camp Commandant
Well, I didn't get to spend the time I wanted to on the truck this weekend, too many chores. I did however move the truck into its new "temporary" winter storage barn. It started right up with the choke pulled like normal. When it was warm I moved it around and prepared to back it into the barn. It sputtered and acted like the choke was stuck, it appears to operate fine. Because it is an updraft, fuel was running out the bottom of the carb. I was suspecting the vacuum advance as previously suggested, but could it cause this. Even after it was in the barn and shut off, gas still ran out for a minute or so.
~ Billy
#11582 11/18/2003 2:22 AM
Bill, with gas running out of it like that when it's parked, it sound's like the needle valve in the carb isn't closing completly because of dirt or just normal wear. Has the carb been cleaned or rebuilt? For an updraft carb you can remove the bottem of the carb without taking the whole thing off of the intake.
I think a stuck needlve valve or dirt in the seat would cause sputtering.
Anyway, good luck and let us know what happens.
Union, Justice and Confidence
#11583 11/18/2003 2:24 AM
Junior Member
Junior Member
Bill,
I am not to familiar with the updraft carbs on the COE but we had them on old farmalls and it sounds like your float might be sticking and not shutting off the fuel flow. Happened a lot when they sat for a long time (like all winter) and the carburetor gummed up. Of course it could easily be something else, too.
I really enjoy looking at the pictures we took of your truck down in Waldorf. Maybe we can get together at a local show next spring.
Pete
Doug Peterson
53 Chevy Pickup
#11584 11/18/2003 2:57 AM
Camp Commandant
Camp Commandant
Swampcat, yea it was running out of the carb when it was parked, and even after the motor was shut off for a minute or so. The carb looked to be rebuilt or maybe even a replacement when I got the truck, but I haven't done anything to it. I will definately look hard at this carb.
Doug, I was thinking it possibly could be the float even though admitedly I don't know that mmuch about these carburetors. I hopefully can spend some time on it tomorrow night.
It was great meeting you all at the show this summer and I defineately would like to meet up at a show in the spring. I would love to check out that beautiful truck of yours again too. I feel I missed out on a couple of shows around here at the end of the summer so I will be ready for '04.
I will keep you all posted on what I find, thanks a lot for the help. Bill.
~ Billy
#11585 11/18/2003 7:18 AM
De Oppresso Liber
#11586 11/18/2003 12:36 PM
Camp Commandant
Camp Commandant
Thanks for the diagram Ralphy. Thats a great view of my carb.
~ Billy
#11587 11/18/2003 5:02 PM
Bondo Artiste
Bondo Artiste
Wow!! Great diagram, and I think the carb deal sounds like the way to go.
Bill, let us know what you find out.
~ Phillip
#11588 11/22/2003 11:05 PM
Camp Commandant
Camp Commandant
Well I finally got a little time to work on the carb problem....no excuses today with temps over 70 degrees.
I took the whole carb off because it was easier to separate on the bench than under the truck. When I got it apart it did seem a little dirty. I used a generous amount of carb cleaner on it. I have to remind you that I am no mechanic but it apears that everything is open and working correctly. I went through the book and the one thing that has me puzzled is where it talks about adjusting the float level. "Proper float level should be from 1/32 to 1/16 of an inch below the top of the float chamber". Mine is greater than that. I'm not sure if that has anything to do with my problem. I ran out of time but I still want to look at the "float lever" and how it seats against the "seated neddle valve". Right... sounds like I know what I', talking about. Hey, I'm learning, thats the main thing.
~ Billy
