| | | Forums66 Topics128,136 Posts1,056,428 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | My 52' AD has what is probably the common 3 cracks all the way around each spoke of the wheel next to the hub around the horn button. Is this refinish-able and is there a kit that someone might recomend? I like to keep as much of the original as possible. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Yes it is repairable , though I don't know of any kits . I have filed out the crack on one wheel and filled the groove with aluminium filled epoxy , then dressed it smooth and painted the wheel . On another , where the wheel was so bad that some bits had come out and the crack was a 6mm gap , I wound copper wire , several times , around the steel shaft that is inside the s/wheel then did the epoxy thing . A good mid winter job ,, ( read that as , "an exercise in patience" ) ,, | | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | I used 'flexible' epoxy, used in repairing composite car bumpers. I started by 'opening up' the cracks with a sharp blade (some of them up to a quarter of an inch). This will allow the material to sit nice and deep.
After drying, the blade can be used to 'shave' the epoxy till it's level, then use 220 grit paper followed by a 400 water sanding. A nice coat of primer-filler followed by a few coats of lacquer in the color of your choice. Voila!
The cracks WILL eventually come back:( . The integrity of the original 'molded' steering wheel has been irreversably affected, but they will show up as hairline cracks.
Hope this helps?
whizzerick | | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | This is just the project I'm going to start this next weekend. It's really nice having an extra steering wheel to work on. Earlier this year I found tons of ideas and helpful hints from the bolt. Many recommend using a fine blade on a dremmel, cutting a V shape grove where the cracks are, and filling it with PC-7 Epoxy. Sand it out, paint it, etc. There's no reason for it to not turn out purtiful
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | I think it's POR15 that makes a kit for this. That's what I used and I'm happy with the results. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | When you cut a V groove you are depending on the adhesiveness between the old material and the new material. By cutting a V you increase surface area. But generally it will let go again eventually.
What you want to do is what a dentist does. The deepest part of your groove needs to be wider than the top of the groove. Making an upside down V groove. Now, even if the two materials eventually delaminate, the patch material can't fall out.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | My wheel had small cracks, nothing structural but it looked bad. I mixed up a puddle of JB Weld and let it run into the cracks (flexing the wheel when the stuff is runny gets it into the cracks). Once it set I sanded it smooth and painted the wheel. I know this is a temporary fix, but it's held up well for a year and still looks great. edit: It also worked very nicely for filling a chip next to the horn button; I just put a large (excessive) drop of JB Weld on the chip and once it set enough to stick I flipped the wheel over so the drop was hanging. Again, let it harden, sand it, paint it. You need a magnifying glass to tell where that patch is.  | | | | | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | I cut the V grooves down to the wheel's steel core for good adhesion. Mine had cracks at both ends of all the spokes and 17 around the rim. Took awhile but looks fine now. The Eastwood Company has PC-7 in small cans for a good price. It's enough to do several wheels. If you have just a few small cracks you can get a dab of the stuff for more money at Chevy Duty.
Never start vast projects with half vast ideas.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Chevy duty has nice repop steering wheels available for pretty reasonable.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I received a very poor repaired and primed 1954 steering wheel from Chevy Duty. It had not been well shaped or sanded. By the time I realized that their product was of poor quality, it was too late for a return.
The repaired wheel I received from Golden State Pickup Parts is, on the other hand, beautiful.
From now on, I will repair my own, using one of the steering wheel repair kits mentioned above (or JB Weld).
Tim | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Eastwood sells a "Steering Wheel Restoration Handbook," written by a former professional. Didn't cost that much, well worth it. I'm going to start on my spare wheel fairly soon, following the book's instructions. | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Used the POR15 epoxy putty on two steering wheels and a dash. Works well. Cleans up with water and you can "sand" with a damp finger or cloth. Have tried other products that do not work nearly as well. | | | | | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | Golly Gee! Didn't expect such a response! But never too many replys. We all have different experiences and takes on outcomes and methods used. Thank you all very much. Now, could anyone reccomend a paint that would stand-up to 'Power Grip Steering? | | | | | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Yes , epoxy paint is what you want to use .
I wimped out and had my steering wheel restored by Koch's in Canyon Country , Ca. , they primarily do old VW & Porsche wheels but they do the steering wheels for the local Corvair club and those guys are _picky_ ! .
I bought a used wheel from someone on this list , Had Kock go at it and now it is the most commented on part of my truck , it's been holding up quite well in several years of commercial service , ofttimes I'm working in the field and must needs drive with dirty grimy sandy hands - so far it's always cleaned up with a wet rag....
Reading the manual by a steering wheel restorer , he says it is most important to open up _any_ cracks down to the metal and clean it perfectly . of course this is why I wimped out , I'm too darn lazy to do all that .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 |
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | |
