| | | Forums66 Topics128,094 Posts1,056,489 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Hi Anyone have a pic of the clutch linkage from the pedal to the bell housing. For some reason, the linkage on my truck is not lining up. The link is pushing the l shaped clutch adjusting rod papers to be pushing outward Thanks Chris 51 chevy coe | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Hey Kent That is mighty kind of you to take the time to send these pics. I really appreciate you doing this. The pics are a big help. I sometimes get stuck as I have no truck around to look at. I hooked up the linkage as your pics indicate. The linkage connecting to the clutch fork looks to be on a bit of an angle. It appears to be on an outward angle. Just wondering now if that is correct. Thanks Chris | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 |
