4 members (Bill Hanlon, Otto Skorzeny, gswbbc, dt235sd), 83 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#1156847 03/25/2016 10:00 PM
Haven't had seat back out yet, but did put some clean fuel in to see what comes out. ( have been using new rubber line to small engine bay tank for testing things so far) Well the rubber line from valve under cab floor started leaking all over the place. Anybody know a GM part number for this or Napa anything I can use to look up? Also is there mote rubber from tank to this valve?
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
52vff #1157236 03/28/2016 1:09 PM
IMHO you should get rid of the clear hose and replace with metal, cheap, durable and no worries of dry rot.
Though I can not help you with a part number, you might consider checking LMC or Classic Parts Of America for replacements. You can probably get a whole kit for your truck. In my task force there is only a 6" rubber section between the cab and the frame. I got a replacement rubber section from classic parts and the rest of my lines were replaced with 5/16- copper/nickel I picked up at advanced.
