| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Haven't had seat back out yet, but did put some clean fuel in to see what comes out. ( have been using new rubber line to small engine bay tank for testing things so far) Well the rubber line from valve under cab floor started leaking all over the place. Anybody know a GM part number for this or Napa anything I can use to look up? Also is there mote rubber from tank to this valve? Thanks | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | IMHO you should get rid of the clear hose and replace with metal, cheap, durable and no worries of dry rot.
Though I can not help you with a part number, you might consider checking LMC or Classic Parts Of America for replacements. You can probably get a whole kit for your truck. In my task force there is only a 6" rubber section between the cab and the frame. I got a replacement rubber section from classic parts and the rest of my lines were replaced with 5/16- copper/nickel I picked up at advanced. | | |
