| | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 54 | I am starting the rebuild on my box. Both rear stake pockets are beyond repair. I have new ones, but can't see any spot welds/welds on the old ones. I hate wrecking more than I have to, has anyone cut them off and left a layer of old tin and just weld the new one to this? Any suggestions would be welcome. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year?
1946 1/2 ton Chevrolet?
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Don't know the accessability of the area, but if you carefully hand sand the flanges with a medium emery cloth on a flat block, when most of the paint and rust are removed and you are seeing bare metal, the witness marks of the spot welds will become visible. They may be faint, but a pattern will emerge because they will retain some paint/rust. | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | What Jim ^ said.
Or you can drive a chisel between the bedside and stake pocket, which will leave a somewhat bigger depression at the spot welds that you'll be able to see. Don't go too crazy and bend the bedside too much.
I had to remove one of mine which was both rusted and crunched.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
