5 members (dt235sd, RdsLessTaken, Woodcmiami, Danielbolt, Gazz), 106 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
#1157108 03/27/2016 5:26 PM
Hi
Anyone have a pic of the clutch linkage from the pedal to the bell housing. For some reason, the linkage on my truck is not lining up. The link is pushing the l shaped clutch adjusting rod papers to be pushing outward
Chris
51 chevy coe
Chris,
Here are links to four pictures from my 50 Chevy COE. The pictures start with the firewall where you can see the clutch pedal bumper and progress to the adjustment nut on the clutch fork,the last 3 photos taken from underneath the truck. I am hoping you can orient yourself by other recognizable parts. Good luck and let me know if I can help further.
Kent
http://s1116.photobucket.com/user/1950Cabover/media/IMG_1474_zpsdk9ux7to.jpg.html?sort=3&o=1
http://s1116.photobucket.com/user/1950Cabover/media/IMG_1472_zpsshfpapra.jpg.html?sort=3&o=2
http://s1116.photobucket.com/user/1950Cabover/media/IMG_1471_zpstxwhc2m7.jpg.html?sort=3&o=3
http://s1116.photobucket.com/user/1950Cabover/media/IMG_1470_zpsn2ihygig.jpg.html?sort=3&o=4
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Hey Kent
That is mighty kind of you to take the time to send these pics. I really appreciate you doing this. The pics are a big help. I sometimes get stuck as I have no truck around to look at.
I hooked up the linkage as your pics indicate. The linkage connecting to the clutch fork looks to be on a bit of an angle. It appears to be on an outward angle. Just wondering now if that is correct.
Chris
Chris,
I found some old photos taken during the tear down of the truck. I don't know if these help but here they are. I would be sure the pivot is not turned around which would change the orientation of the rod that pushes the clutch.
http://s1116.photobucket.com/user/1950Cabover/media/IMG_0372_zpsawmb4pxh.jpg.html?sort=3&o=31
http://s1116.photobucket.com/user/1950Cabover/media/IMG_0371_zps71rehs8r.jpg.html?sort=3&o=32
http://s1116.photobucket.com/user/1950Cabover/media/IMG_0370_zpslnxkitow.jpg.html?sort=3&o=33
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
