0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | I have a 53 that I drove in high school that has been in a field for about 8 years. I do (seriously) plan on redoing it in the future. However, I am finishing my 54 and also just got a 68 plymouth satellite that are in line first since they are both basically road worthy but just need tlc.
The quuestion is: What kind of paint or product can I use on the top of the cab where the paint is gone due to the sun baking it for 51 years?
POR15, Krylon, or what? I don't really want to sand it down etc. but I suppose that is allways a possibility. I'm thinking of a cheap temporary fix to stop the rusting process.
Tim
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | wd-40 put on thick? works on my ax
Bill | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | A lot of folks use "Zero Rust" It is cheaper than POR15, can be sprayed or brushed on and claims not to need much surface prep. For just a holding pattern, it might be the ticket. It can be found at auto body stores. Steve O | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | get a bucket of grease and a spounge put it on thick it will be at least 2 years before you even look at it or get a tarp and bunde cords i have the same problems im just trying to get mine all under cover thats the best | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Hit that top with some 320 to knock the loose stuff off and seal it up with a rattle can of Zero Rust. Nothing simpler in the world and no residue around to comtaminate when you're ready to proceed with the paint prep....... | | |
