1 members (baldeagle), 79 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#115695 01/13/2005 7:55 PM
I have a 53 that I drove in high school that has been in a field for about 8 years. I do (seriously) plan on redoing it in the future. However, I am finishing my 54 and also just got a 68 plymouth satellite that are in line first since they are both basically road worthy but just need tlc.
The quuestion is: What kind of paint or product can I use on the top of the cab where the paint is gone due to the sun baking it for 51 years?
POR15, Krylon, or what? I don't really want to sand it down etc. but I suppose that is allways a possibility. I'm thinking of a cheap temporary fix to stop the rusting process.
Tim
53 3100
1929 Ford Roadster Pickup
1934 Ford Pickup
68 Plymouth Satellite RR Clone 2 Door
My Fleet
#115696 01/14/2005 4:31 AM
wd-40 put on thick? works on my ax
#115697 01/14/2005 6:43 PM
A lot of folks use "Zero Rust" It is cheaper than POR15, can be sprayed or brushed on and claims not to need much surface prep. For just a holding pattern, it might be the ticket. It can be found at auto body stores.
Steve O
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
#115698 01/15/2005 10:54 AM
get a bucket of grease and a spounge put it on thick it will be at least 2 years before you even look at it or get a tarp and bunde cords i have the same problems im just trying to get mine all under cover thats the best
#115699 01/15/2005 6:34 PM
Hit that top with some 320 to knock the loose stuff off and seal it up with a rattle can of Zero Rust. Nothing simpler in the world and no residue around to comtaminate when you're ready to proceed with the paint prep.......
