1 members (1 invisible),
107
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | The manuals don't go into much detail. Can anyone confirm if the 3-position switch on the 47 + 48 trucks are:
Left turn to lock Vertical is Off Right turn is On
I've heard that if you remove key in left position, it's locked, but if you remove it in vertical, you only have to thumb the switch to a right turn and it can be started, without the key! I can still spin the starter in all 3 positions with the key in on my 48.
Thanks! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | When you spin the the starter in each key position, will the engine start in all key positions? | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Funny question, because I'm working on getting the engine started for the first time! So I don't quite know at this point. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | lf its like this one Both left and right are off Center is on Right -off. You can pull key out and operate to on with no key | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Geez, I wish I had've known that! I haven't had it out, but the tumbler looks similar to the one in the pic. Guess i'll have to try it again in a vertical position. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | My 1954 switch was wired "backwards" (in 1971) - however, it started every time when the key is turned the wrong way.
For old times sake, I mis-wired it the same way during the "restoration". It still starts (and turn off) just fine (in a backwards manner).
[I do not know if the 54 switch is different from earlier switches]
Last edited by tclederman; 03/21/2016 2:38 PM. Reason: added comment on 1954 switches
| | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | So, would the points still fire if the ignition was in the 'off' position (with the key in)? If not, then perhaps mine is wired differently...
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The switch is very simple inside. The only place that any contacts make contact is in the vertical position. Both the left and right position has the contacts insulated. Yes if you take the key out in the center or right position you can turn it off and on without the key. Know many trucks that haven't had a key for years. | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Thanks everyone, it seems like such a simple question, but where else but here would I be able to get an answer?!
I will report back once I get a chance to test it out. | | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | My 1954 switch was wired "backwards" (in 1971) - however, it started every time when the key is turned the wrong way.
[I do not know if the 54 switch is different from earlier switches] I am trying to wrap my head around how wiring a simple on/off switch backwards would change which position would be "on". How many positions are there on your switch? Carl
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | So I was able to confirm the switch position last night. With the key vertical, I was able to get it to start briefly, but it died after a big back-fire. Oh well, it's getting closer! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 1947-1953 ignition switch is different from the 1954/55st ignition switch. My postings in this thread are not pertinent - sorry. Also, the 1955 and later foot-starter ignition switch is a different part number from the 1954/55st ignition switch (they also have a slightly different sized escutcheon ring). Sorry about adding confusion to this topic; but, mine is wired "backwards" (right-is-off and straight-up-is-on), and it works fine: on/off/accessories and removing key with engine running. I do not remember if I am correctly using the accessory terminal (or, if I am using the "hot" terminal for accessories)? When I get around to fixing/checking this, I'll try to remember to post the results. | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | The center (start and run) and right (turn on/off w/o key) was a handy combination on the farm when the truck might be needed by several people. Keys were a nuisance.
My glass shop ran my '48's battery down trying to start it in the right position. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Ignition Switch Changes Jim Carter truck parts Tech Article. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Looks like the jc article differs from the film strip. Third paragraph | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Looks like the jc article differs from the film strip. Third paragraph The film strip looks like a switch that is installed in a passenger car. Maybe that is how GM wired the switch for the passenger car. At first I was thinking the switch in the passenger car was a spring loaded switch. Where as, once the engine started you would let it spring back to the ON position. But in 1949 the passenger car had the film strip switch and also a push to start button. With a solenoid starter. 1949 Chev passenger car starting procedure pdf page 31 under StartingThe truck used a floor foot activated starter. Maybe that is the reason for the different, ignition ON positions. Then again JC article may be incorrect. It's how the rear terminals are wired. I don't know which is better on how the Coil is energized, when cylinder is in the: A. Center position B. 2 O'clock position Both the film strip and the JC article agree the switch is locked when the cylinder is in the 10 O'clock position. You need the key to move into the locked position. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I Purchased one of those a few years ago, just have not installed it yet. If I remember correctly the housing is diffrent than the 2 position switch.
Although both have 3 terminals
Might have to dig it out and meter it. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | |
