2 members (Cletus1950, 1955 1 Series), 93 guests, and 3 robots.
Topics128,128
Posts1,056,666
Members48,450
Hello all,
Does anyone have any pictures of the original V8 linkage, still in the truck with the throttle cable installed?
Thanks in advance
It would have been a rod from the pedal not a cable,
http://www.hollisterroad.com/proddetail.php?prod=1013
the tabs bolt to the outer firewall with the short rod going to the inside of the cab and the long rod to the carb
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.thoroco.com
Summit has them
the question is regarding the hand throttle connection to the foot pedal mechanism
You're talking the steel cable that attaches to the arm, right? I don't have a photo and I missed a chance to take one. If you get one, let me know. If I can find one, I'll let you know too.
1959 3100 Apache Fleetside
I have a couple pictures loaded in this photobucket file.
The repro linkage is missing the Throttle Cable Arm. The cable comes through the firewall and turns straight down to connect with the linkage arm. When the cable is pulled out at the dash it pulls up on the linkage arm which in turn pulls the gas pedal linkage back as if you stepped on the gas pedal.
http://s160.photobucket.com/user/st...%201_zpspjzdgrv9.jpg.html?sort=3&o=2
Hope these pictured help.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I remember the one I saw had a swedge on the end.
I believe they have an adjustable barrel clamp.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Yes, you are right. It did look like a barrel, I didn't give it a hard look to see how it was affixed to the cable, which I should have done. I assumed it was swedged on. I hope they are available so I can connect my cable to the arm on my linkage.
Big Bolt Forum Moderator
would something like this work on there?
http://cliff.hostkansas.com/images/2012/CableStop.jpg
Mike
Yup, they will work just fine, just confirm the cable size before ordering them (1/16" might be to small, maybe 1/8"?).
A good hardware store may have them in there misc nut/bolt drawers as well.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
69Cuda: Those would work.
you can search Ebay for wire stop, or take a bolt or other piece of round stock (aluminum would probably work fine as well) and make one. Easier to drill the hole for the cable in a lathe but, you could make one in a few minutes and get it done!
http://www.ebay.com/itm/4-Throttle-Brake-Cable-Wire-Stop-Fits-Vintage-Mini-Bikes-Predator-212cc-/181077190696?hash=item2a290aa828:g:ZFEAAOSwaNBUb3z2
Mike
Bingo! Thanks a lot guys!
Hopefully I will be able to get cracking on this thing soon!
