1 members (TexasJim50),
119
Mod | | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | The exhaust system for my 41 1/2 ton came with a spring, does anyone know where it goes (or if it belongs on this model at all)? Thanks Scott | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | I have a 41 also and if it's a round spring about 1 inch diameter it goes on the manifold. On the underside of the manifold there two little rods that stick out the side of the square part of the manifold. The spring goes on those. Hopefully that makes sense, put in a picture. If that's not the spring your talking about and I'm assume we're talking stock exaust, I dunno of any othe springs on it. | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | This is a pull spring that looks the same as the one used on the clutch and brake pedal return. scott | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Paul, the new spring I received is the same diameter but shorter. My original head pipe has that same clamp and I assumed that it may play a part in this. What is that, a wire hanger coming off the frame rail? Thanks Scott | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Scott,
Yes the small wire "hanger" just seems to extend the length of the spring. It can easily be fabricated from a section of spring steel.
You must be nearly done with your project. Have you driven it yet?
Paul | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Yes I have driven it up the street and back a couple of times. I am in the process of insuring and registering it and waiting on tires. Thanks for the info. Scott | | |
