2 members (VicZ, oldsteve),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | it may work out best if you were to tilt the cab on it's back in order to repair. I built a jig out of 2x4s when I painted the bottom of my cab, and you can paint and undercoat it at the same time. sorry, no pics of my jig! Mike | | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | Thanks, I can see tipping the cab onto the firewall, because I need to have access to back of the cab.
I think I have my access solved, the issue is the installation of the patch piece.
Jeff | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | looks like you may have to: cut out the spot welds, if any, to remove the old brace, shouldn't be too much of a job to remove the old, take your time, and pry them off carefully. Look at the Factory assembly manual to see how they look on the sheet. Mike | | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | Mike I made a bit of progress today (baby steps, but still progress). I finally discovered how those silly inside corners get installed. I'll take a look at the Factory Assembly Manual, great idea!! Thanks Jeff
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Keep us posted! and post pics as well. Mike | | |
