0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 6 Member | | Member Joined: Jan 2002 Posts: 6 | I need ideas and recomendations for restoring and removeing rust off a frame. Is sandblasting the best way to go? If so, what type of sand do i use? Thanx Travis Wood | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Use the "search" for "sandblast" in Paint and Body. 40+ hits, lots of good info. Personally, I'm in the wire wheel and ZeroRust crowd. My little sandblaster was a POS and much slower than the 4-1/2" Dewalt angle grinder with a knot type wire wheel.
[ 01-03-2002: Message edited by: chuckthetruck ] | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I sand blasted my first fame last summer.I used silica sand and black blasting media from manards.The blast media worked much better than the sand.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Travis, I found a guy locally that does sandblasting in his yard (with a BIG blaster) after he gets off work. Did my frame for $100. Ask around, there's lots of people with blasters.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Jan 2002 Posts: 6 Member | | Member Joined: Jan 2002 Posts: 6 | I've decided to sandblast the frame, but I have a few questions. - Are there any specific kind of sands or other materials that would be recommended, and if so can i reuse the sand? - What parts should I take off the frame? ie. Suspension parts, brake parts?
Thanx for the advice
Travis | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | you need to remove everything that is bolted on. Some people go so far as to strip it completely, removing what is riveted on, too. You should be able to buy some fine blasting sand locally. If you want to re-use it you need to keep it dry and screen it.
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | You don't have to take everything apart right now. You can leave the axles and wheels to help in moving it around. Also when you flip it over you got something to land on. When you get all done you will have to remove axles and springs, and what ever else you left on. The springs will need to be taken apart to clean out the sand and to regrease between the leaves. The brakes and bearings will need replaced. The tie-rods and any other joint will need rebuilt or replaced. The rear axle will need cleaned out and new lube but in. The sand will go and get in everything.
All this will need done anyway if you are rebuilding the truck. If you are just wanting fresh paint, go with the wire brush and paint method.
You will need to wash the sandblasted parts before painting. Check with local paint shops for some type of cleaner. Most types will derust and leave a coating behind for paint to stick better.
Make sure your engines is no where near the sandblaster. I buy sandblast sand from my local ACE Hardware store. Its about $4.75 for a 80# bag. If you reuse the sand you could get buy with 4-5 bags if you blaster works good. If its slow expect to use a lot more sand. Also plan on your compressor running all the time, set up cooling fans and water drains or dryers.
I rented a 200# pot and pull behind compressor from a local rental shop. It was around $100 for the whole two day weekend. I used 8 bags of sand and did the intire truck cab, running boards, hood, grill area, doors, and part of the frame. I blasted the inside, top, and bottom of everything. The frame I had done by a local shop for $100. I just touched up some that they missed. They went out of business before I could get the cab done.
Plan on getting dirty and having sand around for along time. Joe | | | | | Joined: Nov 2000 Posts: 17 Member | | Member Joined: Nov 2000 Posts: 17 | Travis: Seems you got more thumbs up for blasting your frame than not, but let me throw out an idea: If you use Zero Rust as chuckthetruck and others have done here, you do NOT have to blast to a white metal to achieve your desired results. As with any restoration, some guys are purists and don't want to take chances with rust - I ain't goin' to argue! However, for those on a shorter time fuse and/or budget, Zero Rust can be used over less well prepped substrates and still do a very adequate job. The secret is in getting rid of any loose or powdery rust which entraps air (thus oxygen) and any contaminants that will interfere with good paint adhesion. Many guys have used a metal conditioner, like our Prep-Step, either shot through a power washer or directly by brush or other means and made this work. Thinned bulk ZR can be shot up into your frame's inner workings, or as one of our user's suggested, using a larger toilet brush to coat those hidden areas. HTH WK Irish | | | | | Joined: Jan 2002 Posts: 6 Member | | Member Joined: Jan 2002 Posts: 6 | Can you paint over Zero Rust after it is applied with any common automotive paint? | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Has any one else used the black blasting media?When i sand blasted my frame i got abought 3/4c done and ran out of sand.The lumber yard i got my sand from was closed and i went to manards and bought there bagged blasting media.It comes in a plastic bag with a channel in the side of the bag.Its set up for the suction tube type blaster.It claims that it has more jagged edges than the sand and must cause it hurts a hell of a lot more than sand when you get it in your eye.I found that for the frame it worked substantually better than the sand for abought the same price.It went faster than the sand and and did a much better job.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Nov 2000 Posts: 17 Member | | Member Joined: Nov 2000 Posts: 17 | ZR can be topcoated with just about anything, the only potential problem is with automotive paints that use a considerable amount of acetone as their VOC, which can cause lifting of the ZR due to its aggressive nature. This can be overcome by simply shooting a light tack coat to "seal" the ZR surface, then come back and shoot your flood coat. Alternatively, if you like the finish of the ZR, leave it uncovered. OR, if you want some UV protection and perhaps a little more gloss, shoot a couple coats of our Crystal Coat and you've just finished the race! HTH WK Irish | | | | | Joined: Jan 2002 Posts: 6 Member | | Member Joined: Jan 2002 Posts: 6 | I am looking at buying ZeroRust for personal use but I would like to find a Canadian Distributor.
Thanx travisw7 | | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | I'm selling it here on Vancouver Island ... (cant sell you any on this page though ... contact me via email) ... Did I slip that in ok OLY? :confused: | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Sure it's ok Fat. Some people can get away with anything here, others just get banned.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Well a few things here to clear up- First, I am the Moderator of the Lounge (no where else on this site). Two, Fatfenders why don't you have a link posted in the Links so that folks can be sent your direction better. Third, Tony M I believe that this was "hashed" out to everyones satisfation a while back. If you still have a "problem" with something, please feel free to contact me, email- [email protected] , or contact me via MSN, or call me direct- 541-445-2919, OR stop by any time, be glad to give you directions to my front door. This is not "MY" forum to moderate- but, Tony M., If you are trying to cause a "stir", I surely won't tolerate it in the Lounge.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Oly, I don't want to cause a stir and have already been called to the Nascar trailer for my punishment by the brass.
I am only responding to your post because I don't want you to think I am a trouble maker. I was already told to refrain from said posts. I posted it because, unless stuff happened that I don't know about, a friend of mine had been banned for identical postings. I did also forget to add the LOL you told me to include.
I will refrain from these posts. Especially as my friend's account has been reinstated. Welcome back M.T.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Its good to be back Tony. Now lets get back to old truck stuff.  | | |
