Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Phak1, Otto Skorzeny, Tinker5), 183 guests, and 5 robots.
Topics128,274
Posts1,058,436
Members48,490
#1143632 01/08/2016 2:54 AM
I put new wipers and blades on the '53 3100 that I've been working on for over a year now. The wiper vac motor could turn the splined stub shafts, but when I put the wipers on, it was a no go. So I took the vac motor apart, cleaned it good, figured out how it worked, and assembled it using petroleum jelly (Vaseline). It was congested with dried up old grease, but all the rubber looked in relatively good shape. I also cleaned and lubed all the linkage pivots and stub shaft bushings. Thanks to this forum for all the info I found by searching this subject, the wipers are working like a champ now. Those vacuum motors are quite the ingenious little mechanism. I think it's as much fun to learn how some of this stuff works and repair it as it will be to go cruising in the old truck!
I am going to try the same thing on my 46. The folks at Wiperman.com no longer have the parts to do 46 wiper motors.
Big Bolt Forum Moderator
good job getting them working again! I did the same on my Willys Wagon years ago.... worked pretty well aster that! I did re-lube the motor every couple years though but, I also got it pretty dusty and muddy from time to time!
Mike
Moderated by  ndkid275, Phak1
