1 members (Otto Skorzeny), 115 guests, and 0 robots.
Topics128,049
Posts1,055,549
Members48,425
#1155895 03/20/2016 6:39 PM
1 Offline
Last night I was driving around my '54 3800. The dash lights were working. I stopped at the gas station, turned the lights off. When I got back in the truck I pulled them on and the dash lights didn't go on. Headlights and all still work. I'm assuming that the bulb (s) blew? I can't find anywhere in the manuals about where the lights are. How should I fix this problem?
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
It seems odd that all of the bulbs would go bad at one time. I had the same problem with my 52panel and it turns out the NEW light switch is defective. I could twist the knob back and forth and would "sometime" see the dash lights flicker.
Perhaps you have the same problem??
...and of course, check the fuse panel for a bad fuse.
1 Offline
So I'm a beginner in a lot of this but the first thing I thought of was a bad fuse, however, didn't think this truck had fuses. Would they be under the hood in the black box attached to the fire wall?
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm1240.html
See if you have voltage at the instrument light terminal [ shown upper right, Fig. 62 ].
Joe
The dimmer rheostat on the light switch stalk is the most common cause. Try twisting the knob back and forth vigorously to see if you can rub away some of the corrosion. If that doesn't work, get a mirror up under the dash and look at the back of the light switch- - - -some of them have a built-in fuse for the dash lights. Last resort is a new switch.
1 Offline
It was the dimmer switch, it now works with a little wiggling back and forth. Thanks!
If you can remove the knob, you could spray this rheostat cleaner/lubricant (or something like it - preferably with no silicone) to clean the oxidized contact surfaces.
1 Offline
Good to know! I'll try it!
Yep the light switch. Common fails: dirty, burned out resistor and, loose wiper. On the AD type there is a "circuit" breaker like bit. Those contacts can get burned and dirty as well. Isopropyl based works well. No power when using please, it will burn until dry. Drys fast and cuts oils/grease, no silicone.
https://www.zoro.com/crc-contact-cl...CPnuh5CQ38sCFWveMgod0v0PjA&gclsrc=ds
Steve H
