4 members (Gdads51, 55shaker, Bruce 1954-4100, Hanks custodian), 101 guests, and 2 robots.
Topics128,109
Posts1,056,253
Members48,437
#1155828 03/20/2016 4:14 AM
Ready for a good laugh? Read on....I think I'm getting to old for this!
Rebuilt a '56 truck 261 engine for my 50 coupe and finally got to start it up today and then things got exciting.
Everything on go...or so we thought. Put the gas to it and after it turned 2 or 3 rounds there was a little "ka-pow" like a rifle. OK, gas getting to carb. Turn it again and "ka-BOOM, like a cannon. Ok, OK, so the distributor is 180 off. Reset the distributor and it started right up. 50lb of oil pressure (had already primed it up) and temp rising. Saw temp gauge drop back a little and figured OK, the thermostat just opened. Ran it for at least 15 minutes and the gauge started climbing. Mmmmm, I'm think its getting a little too warm....lets stop and check things. Then POW.....the radiator hose blew off the water pump about the time I turned it off.
...well, wouldn't you know it was something stupid. I had pulled the cardboard from the engine side of the radiator that I had protecting the nice aluminum fins. I THOUGHT my Nephew's son was pulling the cardboard off the front of the radiator. Nope, cardboard still there. Problem solved.
Mopped up the mess, and wondered if very much got in the carb. Hit the starter and it fired right up. Man, does that 261 run sweet. Very good throttle response and the engine seems strong and just chewing at the bit's ready to go. How sweet it is. Am I smiling? you bet.
A little fine tuning and we're good to go.
..and the reason the hose came off?? Since heart surgery and some recent health problems my upper body strength has suffered pretty bad. The hose clamp was just not tight enough. My fault.
Still, a bad day in the shop is better than a good day in the house! This is my "tale for the day". Hope you enjoyed my adventure as much as I did. Man, it runs so sweet.
Way to go Alvin, glad to hear you're having fun in the garage thumbs_up
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Great news Alvin,Pete
Leo Offline
Moderator
Moderator
So it's good even if it's bad, right? You should be very happy with that 261. Congrats.
Congratulations, Alvin
glad it was a happy ending to the story!!
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
