1 members (klhansen), 153 guests, and 1 robot.
Topics128,126
Posts1,056,356
Members48,441
#1155300 03/16/2016 1:36 PM
This truck came factory without a bed and it used to have a grain box on it. My question is about this bracket on the rear, is it a trailer hitch? Am I correct to assume that it's not factory? Will it have to be removed to add a bed?
hitch
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
You are correct, it is not "factory".
Looks like some sort of hitch attachment bracket/bar/frame. The rear cross member is also not "factory"
The vertical plate on the frame rear cross member will most likely have to be removed in order to install a bed?
Thanks Tim, that's what I figured. Is there any benefit to keeping that rear cross-member? Would it be needed if I decide to install a real hitch?
More images
Goach2,
It depends on the real hitch you want to use.
Here is a home-made hitch from Deve.
Here is a "store bought/made" hitch. It works with a 1954 bumper, which could be installed on earlier Advance-Design trucks. It would be nice to hear from someone who has installed it on a 47-53 31xx truck.
I have something similar on my '59 and I believe that you are correct to assume that it is not a factory or dealership installed item
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
My guess is that it was used to move "hopper" (grain) wagons, and home made.
Larry W.
1953 3800 Dually Flatbed
When you say bed, are you referring to adding a pickup bed?
If you're adding a flat bed then the hitch wouldn't likely be a problem.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Yes, a pickup bed, but since I won't be pulling any grain bins, this bracket can go. I would like to have a 'real' hitch in the future, thanks for the links Tim.
More images
It looks like it is set up to accept a ball for towing a trailer. Your bed may sit on top and not interfere with the flat stock.
I would be afraid to tow a decent load with that setup because it does not have any bracing to resist side loading. For really light loads you could mount a ball on the bumper or use a receiver assembly like that offered by Reese that attaches to the frame rails.
