| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | In the process of restoring the above gauge and having disconnected everything execp the lines to the oil pressure and temp. Looks like the oil line unscrews. Same with the temp or does it just pull out? Thanks, Scott 53 1/2 ton. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | if it is a mechanical temp gauge (which I believe it should be) it only disconnects at the engine end. You need to be careful not to damage the capillary tube or it will render the gauge useless. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Temp gauge face can be restored by removing the two small screwa that hold it to the gauge.
Ed
| | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Great advice. Thank you! Awaitng new decals to restore gauges. Scott | | |
