5 members (JeffA, klhansen, dt235sd, Hanks custodian, 1 invisible), 76 guests, and 4 robots.
Topics128,180
Posts1,057,160
Members48,464
Is it practical to remove the brake and clutch pedal shaft while I'm restoring to get the rust cleaned up? I'm afraid if I don't, it'll seize up later.
Then, HOW do you get it out? I don't want to mushroom it.
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
It helps if we know what year and model you're working on...I'm assuming it's the '47, but helps if you say that...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
1962 IH Scout 80
Stephen,
Is there a roll pin holding the shaft in the bracket? The COE pedals look the same as my conventional 1941, but the bracket is totally different.
Paul
Lots more pictures
Wow! Amazing!
There it was, a roll pin hidden in there. Drove it out, then drove the shaft out. Excellent!
Thanks for your help, Paul!
1962 IH Scout 80
