5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#1154534 03/11/2016 5:28 AM
O.K....I am stupid, I have a 54 235 I bought as a replacement. It is sitting in a homemade cradle and I want to turn it over to check compression and eventually get it started. Question is, I don't know how to "hot wire" it to check compression and start. please help an old fool and explain the steps. Thanks
Gas Pumper
Gas Pumper
For just doing that, no need for bypass wiring, or other extraneous niceties, so...
Wire from the distributor goes to the minus side of the coil, a hot positive wire goes to the plus side of the coil. Don't leave the coil plus wire on the coil for long. No need to connect these wires to check compression, just to start.
Plug wires are 153624
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Originally Posted by Deve
Plug wires are 135624
153624
Gas Pumper
Gas Pumper
Doh! Thanks. Listen to Dads!
Deve
The Think Tank
Originally Posted by DADS50
153624
Unless, of course, you are looking for that rad cam effect which the kids seem to be so fond of these days.
