2 members (Gdads51, Greg_H),
83
Mod | | | Forums66 Topics128,151 Posts1,057,005 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 73 Shop Shark | | Shop Shark Joined: Feb 2016 Posts: 73 | Howdy Fellow Stovebolters, Does anyone know if I cant fabricate a hand crank for my truck from another chevy hand crank? I've noticed that different years are different lengths and different bends. I can't seem to locate one for my truck. Thanks in advance, Dave | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | As long as the end of the crank fits on to your engine I don't see why not. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Dave, Your crank is the same for the following cars and/or trucks; 1929 Truck 1930 Truck 1931 ALL 1932 ALL 1933 Truck p/n 352768 Hope this helps, Mike B  | | | | | Joined: Feb 2016 Posts: 73 Shop Shark | | Shop Shark Joined: Feb 2016 Posts: 73 | Still haven't found anything for hand cranks. If I'm googling or Ebaying. I've been putting in "hand Crank" for the subject. Should I be using another search term?
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | may want to consider picking up a copy of Hemmings Motor News, it has a lot of parts suppliers and sources. Ebay in the most part has dried up somewhat and getting kinda pricey. My opinion, Mike | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Yes you can fabricate one, determine what size bar stock you need to fit inside the balancer and go from there. Re. length, it just has to long enough to clear the bumper. There is a recent post here for a 41-46 truck crank, check that out to get a basic idea. I made one from all thread rod to use in the shop for adjusting lifters but you probably want an original looking crank. Best of luck | | |
