| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | My 53 chevy 1/2 ton has an engine with the following casting marks and am wondering if anyone can help me out with ID ? the # on the block to the rear of the distributor o137350 the # on the drivers side head 3835918 the # on the pass side of block 3836283 other # on head 15B 913 241 570 Is this a 235 ???? I ordered parts for what I thought was a 216 engine and the parts do not fit HELP............thanks
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Might the head casting code be: 3835913 instead of 3835918 ? Might the block casting code be: 3833633 instead of 3836283 ? Can you post a link to a photo of the Engine Serial Number? This code often gets messed with on a replacement engine. Please post the head and block date casting codes. | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Tim...new numbers on closer look area between dist & oil blowby tube # 3836233 drivers side head # 3835913 Back of block around starter area CONN 1 B3 55 on dist. ledge 0137350155 Z
Thanks in advance....J
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here are my guesses (someone will correct me, if I'm wrong): 3836233 = 1955-56 block - car or truck (mechanical lifters) 3835913 = 1954/55 head 01373501 55 Z could that be? 0137350F 55 Z 0137350T 55 Z ? http://www.1954advance-design.com/chev-specs/1955-1st-Chevrolet-t-ser.pdfMost likely the codes near the starter area is: CON 1 (not CONN) = Conveyor #1 and the Block date code: B 3 55 B = 2 = February 3 = 3rd 55 = 1955 (is it one 5 or two 5s?) Are you a diesel-engine person? | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | 3836233 = 1955-57, 235 block (mechanical lifters) 3835913 = 54-62 235, 261, head CON 1 B 3 55 or B 25 5 CON 1 =(not CONN) Conveyor #1 B = 2 = February 3 = 3rd day of month 5 = 1955 Source Patrick's Casting number locations Click on pictures to enlarge. 0137350 155Z 0137350 = Units built 1 = more than likely a "T" = Tonawanda, NY, Plant where engine was built. 55 = 1955 Model year Z = Type, Regular Engine, Originally installed in a Passenger Car Source PDF, page 42 I believe the only difference between in a car block and a truck block. Is the numbers/letters stamped into the flat machined boss to left of the distributor. | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | new info...casting # on the ledge in back of distributor # 0137350T 55 Z Previously I had 01373350155Z....so the above is correct. also CONN is not correct...it is CON. At this time I cannot post a picture of the engine serial number, sorry. There are NO captain bars located anywhere so I presume it is NOT a 261 but IS a 235. ????? Tim, I am not a diesel person.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | zoegrant,
I asked about "diesel person" because I have heard the term "blow by tube" more commonly used by diesel engine people.
Blow by tube is also commonly used as a name for the road draft tube on stove bolt engines (I knew what you meant).
It looks like you now know what engine you have?
Extraneous question:
Does the body of water pump on your engine block extend above the top of the block?
The early 1955 engines (truck) had that style water pump.
1955-2nd series trucks had a water-pump body that did not extend above the top of the block.
1955 cars were not designated as 1st or 2nd series (the car body style changed at the beginning of the 1955 model year).
I am wondering if the cars use the 1st series-style engine in early 1955? I think the trucks changed to 2nd series around Mar/Apr 1955. You have an early February block.
| | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Tim...the top of the water pump is dead even with the top of the block....J
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | The center of the fan is 3 1/8 " from the radiator The blades are 2 3/8 " from the radiator............J
| | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Sorry if this post`s twice...sent it once but did not show up.
The center of the fan blade is 3 1/8" from the radiator. The edge of the fan blade is 2 3/8'' from the radiator....J
| | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | The center of the fan is 3 1/8" from radiator The fan blade is 2 3/8" from the radiator............J
| | | | | Joined: Mar 2016 Posts: 12 New Guy | | New Guy Joined: Mar 2016 Posts: 12 | sorry to butt in but I have a casting number question to. my number is 3837004 which from what I can tell is a 55-57 235 but also cast next to this is the word SPECIAL is there really anything special about it | | |
