2 members (baldeagle, MickeyP), 101 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1154128 03/09/2016 12:49 AM
Have two sets of gauges from the T F series (55-59)How do i bench test them? One temp. gauge is sender attached to solid wire(copper/aluminum) Other unit is sender with electric wire to gauge. The rest of the gauges are all the same.
Midpiner #1154130 03/09/2016 12:55 AM
Sir Searchalot
Sir Searchalot
Well as far as temp gauges it sounds like you have one mechanical and one electrical. One with a tube and one with a wire. They are best tested buy putting the "sender" part in water over a heat source and watch gauge compared to a thermometer in the water container. Take it to boil and back down while observing.
The electric is more trouble: You can use a battery or a battery charger for the electric one while in the water. (submerge only the threaded portion).
Read this:
http://www.madelectrical.com/workshop/water-temp-gauge.shtml
Midpiner #1154142 03/09/2016 1:41 AM
I think the electrical temperature sender started being used in 1956.
What year head do you have?
The mechanical sender might need a brass bushing to fit into the head that used the electrical sender. Check the outer diameter of the sender bases.
Midpiner #1154147 03/09/2016 1:59 AM
The head is a 56. Thanks for the advice.
Midpiner #1154149 03/09/2016 2:01 AM
Do both types of senders fit into that head, with no adapter?
The 1955-2nd Task Force Truck "mechanical" sender might have a wider diameter than the earlier mechanical senders. That would be interesting to know.
Midpiner #1154168 03/09/2016 3:38 AM
Gas Pumper
Gas Pumper
I just know that the electrical sender fits in the block with no adapter. Not sure about the mechanical one.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Midpiner #1154277 03/09/2016 9:07 PM
Riding in the Passing Lane
I would sure use the electrical gauge if possible. I was thinking the mech gauge used on 6 cyl. & the electric on v-8.
1972 Chevy c10 Cheyenne Super
Midpiner #1154298 03/10/2016 12:11 AM
Yes both senders fit in the head w/o adapter It is on a 235.
Midpiner #1154301 03/10/2016 12:45 AM
Thanks for that info, Midpiner
