| | | Forums66 Topics128,093 Posts1,056,475 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 24 Member | | Member Joined: Dec 2001 Posts: 24 | can you spray the new enamel paints over the old laquer paint that is orginal with out it showing where you feathered the egdges? Been told yes and been told no. has anyone did this or is there a painter in the house???? | | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | yes you can spray enamel over an old lacquer finish.but you cant spray lacquer over thetop of enamel
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Be careful with the primer over laquer. Some of the new primers out today do not like laquer. I had to strip to bare metal when using an etching primer. | | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | If you are worried about the reaction that the primer may have with the lacquer than use a water based primer
DUSTY G.
