4 members (Wayne67vert, Southerntruck, Guitplayer, Napco Man), 106 guests, and 2 robots.
Topics128,093
Posts1,056,477
Members48,444
#115399 10/15/2002 3:57 AM
can you spray the new enamel paints over the old laquer paint that is orginal with out it showing where you feathered the egdges? Been told yes and been told no. has anyone did this or is there a painter in the house????
#115400 10/15/2002 4:18 AM
yes you can spray enamel over an old lacquer finish.but you cant spray lacquer over thetop of enamel
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
#115401 10/17/2002 5:15 PM
Be careful with the primer over laquer. Some of the new primers out today do not like laquer. I had to strip to bare metal when using an etching primer.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
#115402 10/18/2002 4:02 AM
If you are worried about the reaction that the primer may have with the lacquer than use a water based primer
DUSTY G.
