2 members (ShopRag, LAROKE),
44
Mod | | | Forums66 Topics128,090 Posts1,056,347 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 8 New Guy | | New Guy Joined: Dec 2009 Posts: 8 | Just curious if anyone knows if there is a place that I can buy the wedge shim that is between the axle and leaf spring? I seem to have lost one and haven't been able to locate it.
51 chevy 3100
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy fireman947, welcome, any good wheel alignment shop should be able to supply one, take the old one in with you because they do come in different thicknesses, hope that helps. | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Napa auto parts lists them, they come in different degrees. Scott | | | | | Joined: Dec 2009 Posts: 8 New Guy | | New Guy Joined: Dec 2009 Posts: 8 | Do you know what the part number is for napa, I looked there earlier and didn't find any.
51 chevy 3100
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Saw some on eBay.
Ed
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | 264-4000 is 1 3/4" to 2" by .5 degree 264-4001 is for 1 degree. This should give you an idea for starters on the part #'s for Napa. Scott | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Scott,
I cannot find 264-4000 at NAPA.
Can you post a link to the part on the NAPA site?
| | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Hi Fireman, I recently purchased a set from Benz Spring in Portland, OR. They are called caster shims. http://www.benzspring.com/Peter Seattle, WA | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Belt sander or hand held grinder and make one from flat stock ? | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | The counterman had to look it up in a catalogue. The only ones I found on their website were Rancho 2 1/2". Call your local Napa store with that part number and they should be able to help you. Scott | | |
