Brrrr
place holder
5 members (FishinToms53, Scott, SmalltownTRKGuy, Gdads51, Otto Skorzeny), 168 guests, and 3 robots.
Topics128,271
Posts1,058,414
Members48,485
#1153885 03/07/2016 1:31 PM
Just curious if anyone knows if there is a place that I can buy the wedge shim that is between the axle and leaf spring? I seem to have lost one and haven't been able to locate it.
51 chevy 3100
3B Offline
Hy fireman947, welcome, any good wheel alignment shop should be able to supply one, take the old one in with you because they do come in different thicknesses, hope that helps.
Napa auto parts lists them, they come in different degrees. Scott
Do you know what the part number is for napa, I looked there earlier and didn't find any.
51 chevy 3100
Saw some on eBay.
Ed
264-4000 is 1 3/4" to 2" by .5 degree 264-4001 is for 1 degree. This should give you an idea for starters on the part #'s for Napa. Scott
Scott,
I cannot find 264-4000 at NAPA.
Can you post a link to the part on the NAPA site?
Hi Fireman,
I recently purchased a set from Benz Spring in Portland, OR. They are called caster shims.
http://www.benzspring.com/
Peter
Seattle, WA
Belt sander or hand held grinder and make one from flat stock ?
The counterman had to look it up in a catalogue. The only ones I found on their website were Rancho 2 1/2". Call your local Napa store with that part number and they should be able to help you. Scott
