| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11532 12/17/2003 6:50 AM | | Anonymous Unregistered | | Anonymous Unregistered | has anyone ever checked out putting a sb mopar in an AD? i've been told you don't have to mess with moving the steering colum because the mopar sb are narrower than chevy's any truth to that? thanks tony'n weatherford :p  | | |
#11533 12/17/2003 2:28 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Tony: It problay because they are slanted away from the steering box and shaft good motors also. popcorn The Truth is Out there (Hope this helps) | | |
#11534 12/17/2003 2:57 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I do know for a fact the Fomoco 289/302 is a few inches less wide , but a few inches longer.It's not so much the width as it is the placement of the exhaust ports and head design.I bet the old Buick Nailhead V-8 would slide right in there, available in 425 cubes too.I have seen a few Chevy smallblocks in AD's using the stock steering box just moved over slightly. | | |
#11535 12/17/2003 5:51 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Tony n,, I bet a 440 in your panel would really make it move,,but getting it in there,,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#11536 12/17/2003 9:05 PM | Joined: Dec 2001 Posts: 146 Member | | Member Joined: Dec 2001 Posts: 146 | Tony,
The SB mopar is not narrower than a SB Chevy. But it has a driver's side exhaust manifold that is much closer to the body than the ones You normally have in chevies. I'd not care for installing one in an AD just for this reason. Would be a sort of a crossbreeding and would be somewhat weird to pop up the hood and see such a stranger there. You know, just the 0.02.
Alexandre Garcia
#11537 12/18/2003 6:57 AM | Joined: Oct 2003 Posts: 70 Member | | Member Joined: Oct 2003 Posts: 70 | M O P A R Mash On Peddle And Replac manny old parts at random | | |
#11538 12/19/2003 1:59 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 |
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#11539 12/19/2003 5:02 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I know its been done, but have never seen one in person. I have seen a couple of Advance Design trucks with F*** motors, and somehow that just doesn't feel right!
If you want to minimize the changes you make in a motor swap, why not build a 302 or maybe a 292? It won't make the power of a 440, but should be plenty powerful enough to run around on the street (says the guy with a 454 on the engine stand).
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#11540 12/19/2003 8:45 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | This is just hearsay and not admissable in court but, back in '89 before I bought my 55-1st Chevy I talked at length with a guy who had a 53 1/2-ton for sale with a Dodge 318. He had done the conversion himself and said it was straight forward with no frame mods, moving steering box, etc. He fabbed simple side motor mounts and a crossmember under the trans. Late model rear end and open driveshaft and away he went. I did not see it myself so I just had his word....personally I like the 318 Dodge "small block" motor. Had a good one in a '86 pickup. Still, it would be a morph in an AD truck.
Professional Novice
#11541 12/20/2003 8:11 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Gotta agree about the 318. My dad's first new car was a 69 Plymouth Satelite wagon (triple bench) used to haul the family across country and back (twice). Had a 318 and a 2 barrel with a Chrysler torqueflight 3speed. darn strong car. Rusting away in the late70's/ early 80's, known to my friends as the Royal Imperial Land Yacht, it would walk all over new TA's. Shock the heck out of the guys driving the Camaros. 10:1 compression, no emissions, 225 hp straight to the shaft. The engine had enough torque it used to roll and break the right mount (then the right collector tube... only barked when tromped on.) If you're going to put a non-GM engine in your truck, you could go far worse than a 318 or a 440. Be different, too!
#11542 12/21/2003 6:19 AM | Joined: Apr 2000 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 71 | You fellows are way behind,lol. I put a 383 Chrysler big block in my '46 pickup, years ago. I had to move the steering gear but the rest of it sits under the stock hood and with the stock radiator support. I'm running the 727 trans. and a '69 Chrysler rear end. It makes for a great tow truck, for my race car. All in all, I had still rather have a Chev motor though. :p | | |
