1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 116 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 116 | Is it practical to remove the brake and clutch pedal shaft while I'm restoring to get the rust cleaned up? I'm afraid if I don't, it'll seize up later. Then, HOW do you get it out? I don't want to mushroom it. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | It helps if we know what year and model you're working on...I'm assuming it's the '47, but helps if you say that... Mike B
| | | | | Joined: Jun 2005 Posts: 116 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 116 | | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Stephen,
Is there a roll pin holding the shaft in the bracket? The COE pedals look the same as my conventional 1941, but the bracket is totally different.
Paul | | | | | Joined: Jun 2005 Posts: 116 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 116 | Wow! Amazing! There it was, a roll pin hidden in there. Drove it out, then drove the shaft out. Excellent!
Thanks for your help, Paul! | | |
