7 members (Gdads51, TUTS 59, WICruiser, Phak1, Wheelie, Bill Hanlon, 1955 1 Series),
101
Mod | | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | For several years I've been trying to track down the origin of the bearing and support bracket, the bearing is a New Departure bearing. My problem is the bracket with the rubber is all cracked and not trustworthy. With no part number etc I don't have anything to go on. Maybe someone else has seen this arrangement. I have a 1950 1/2 ton with a 235 4 speed and a GM differential 3.55. ...Glenn (new to photbucket and can't seem to insert a pic, any help on this would be appreciated)
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 |
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | I took a quick look at the 1929-1954 Chevrolet Master Parts list and I could not find anything. 1950 Chevrolet 3100 with a later 235 engine installed, what transmission? IF this is a factory set-up we should be able to find part numbers.
Ronnie
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Hi Dusty53, according to the numbers on the block its a 1954 235, with the GM SM420 4 speed, the differential numbers (3707306) make it an automotive application used 55-57 Biscayne and Belair, also 53-62 Corvette. I have seen diagrams and pictures of steady bearings used in bigger trucks but nothing that looks like this, thanks for checking..Glenn
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Hey Glen, I have to ask....this is a 1/2 ton truck optioned with an SM420 ,or do you think one of the previous owners did a custom install ? Anyway, you may able to substitute for the carrier bearing and support bracket if you know the outside diameter of the splined shaft that fits inside the carrier bearing.Example - www.classicparts.com , part number 92-905, 1.3780 ID. You'd have to fabricate a "riser" to go from the support bearing housing to the frame mount. Wouldn't be stock, but so what, right? If you can take a picture of the entire driveshaft I can do some more research or if you want you can PM me I'll give you my contact information. Hope this helps ! I know the struggle, but in the end its worth it!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Hi Dusty, well the cab was designed for a 4 speed(with cover etc)and now with the original shaft being looked at by a drive line shop they have told me that they couldn't find out the origins of the steady bearing and bracket. the outside diameter is 1.625 so the bearing you mentioned doesn't work, they are ready to machining a wider mating surface for a new bearing and I would make up a mounting bracket to set up the correct position. I would say thanks for the effort as i'm strongly considering this option so that I can go back to these experts if I have a problem. Thanks again, good luck with any of your projects
