2 members (2-Ton, Bill Hanlon), 82 guests, and 3 robots.
Topics128,142
Posts1,056,485
Members48,441
Hello Stovebolters…
Someone in this forum should know the answer to this mystery:
Is the accelerator lever bracket shown in the 55-59 Factory Assembly Manual different from what Chevy actually produced?
Specifically, on RPO 408, Sheet 8.0, Accelerator Lever Bracket (#3724091) is shown. I have been scouring the country looking for this part. The OEM brackets I have located do not look like or mount like the part shown in the manual.
Therefore, is it possible Chevy could have used a different part to accomplish the same thing, or should I just keep looking?
Any help or discussion on the topic would be helpful.
Marc
Love is blind᠁.but the neighbors ain't!
Yes that's it except everyone I've seen has a different firewall retainer. The one's I've seen have two feet, one bent to the left and one bent to the right with one bolt hole on each foot.
The repo are very close, but the retainer has the holes drilled with the wrong hole centers. I took mine apart and made a new retained so I didn't have to drill the firewall.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
haven't seen an original that looks exactly like the bracket #3724091 in the FAM, all [both] have been as Mike sez, 'feet' facing outward - but then, the ones I've seen were 57/8 .... keep in mind that the FAM was for 55 only, doesn't show any subsequent changes that may have been made - the date on that sheet is July 1955, about when actual 2nd series trucks appeared .... the repro ones I've installed fit the firewall holes, but that was later models that might have seen running changes, and the repros may heve been copied from a later item, the firwall stampings changed slightly in 58
I'd say if you're fixated on finding an original, rather than fabbing your own, it'd have to be from a 55 only, don't count on any later years being the same
